scott011422
- Joined
- Feb 5, 2008
- Messages
- 104
I could use some help. Quite often I find myself tapping into a harness for a signal. 99% of the time I'll solder the wire onto the wire I'm tapping. What I don't like is covering the splice once I'm done.
Electrical tape works for a while, then starts to unravel leaving this black sticky goo.
My other, and preferred method is to sever the source wire, slide on some heat shrink, solder the source wire back together while adding the new wire. Then once the splice has cooled, Sliding the tubing over the splice and applying heat to seal and cover the splice.
While this method is the most reliable, I'm never crazy about severing the source wire, especially when it is a signal wire for a plc, control, or data cable that can be sensitive to added resistance or voltage drop from the added resistance.
What else can I do to cover my soldered splice? I've seen a Scotch loc type of clamshell cover in the shape of a "T" that snaps over the joint, but the company was unwilling to name their supplier. I dunno. Any ideas???
