Packhorse
I am slowly catching up with some of my light design ideas.
This one has been inspired from my time out on the local Coastguard SAR boat. At present we are using 150mm 50-100watt halogen spotlights.
These are very disappointing to use for many reasons.
They have a fair amount of spill that falls back on the boat causing disruptions to the crews night vision.
They dont really throw.
They have a terrible colour.
At night when out I will take my modified WF502b that uses a R2 with an aspheric from Ahorton. While it does not quite match the output of the halogens it comes surprisingly close in usefulness.
Anyway I had an aluminium disc lying around and a use sprung to mind.
The pics tell the rest!
I plan on putting a 50-100mm shroud around the LED's to stop annoying spill light from being visable to the crew. The inside of which will be painted black. A acrylic lens on the end will aid in weather proofness.
I will direct drive it with resistors from the boats 12v supply. I will probably add a thermo fuse to half the array so if it over heats at least half will still run. I will start running it at 1 amp each LED and if I have no or little heat issues raise it up a bit.
I am still undecided on the handle. Perhaps pistol grip.
Switch is also undecided. Maybe a toggle and a push hold switch.
