It looks to me like there are two SSC P4's in my 400L. I'm wondering if it would be possible to pull out the "pure" white LEDs and replace them with the high CRI P4.
The specs on Seoul's website appear more or less identical, although I admit I don't know what some of the numbers are referring to. Does that mean that I could swap LEDs without having to make changes to the other electronics? Also, the 400L uses an optic, so are the different P4's the same dimensionally?
If the LED swap I described is possible, would it be as simple as removing the current LEDs and soldering in the new ones?
edit: this is a P4, right?
edit #2: Alternatively, what about using a neutral XP-G and a different optic... are there any optics or reflectors that I could drop into the 400L? Two XP-G's could potentially be a lot brighter than two high CRI P4's.
