Hello,
I've finally got my driver installed to a SST90 @ 9A - impressive.
I have a question though:
What happens when the input voltage drops below 6V?
Your spec sheet states that the minium voltage is 6V, but not what happens below this.
I ask the question because I'm looking at battery options for a 2C maglite. At 3V per battery on any chemistry, the current draw is just over 6A. That's too much for AW's LiCo (PCB cuts out at 5.8A on his latest 18650's), but the LiMN would be fine. The only problem with IMR cells is they're unprotected.
If your driver cuts out at 6V, then running two IMR cells in series will be fine, as neither will drop below 3V each (assuming both cells are charged separately, same age, same production batch, same charger etc).
My bench PSU can only deliver 5A, so I cannot test this myself.
Many Thanks.
