Apologies if this has been asked before: Is there a bulb that would give a scorpion similar performance to a surefire 6p with P61 lamp assembly? If so, I might like to try and get a spare scorpion lamp assembly to make swapping easier. Any ideas?
I have called Streamlight and asked them about it and they said the brightest lamp avaiable is the one in the light. They mentioned a problem with heat build up if you tried to put a brighter lamp in there. I did look quite a bit for a brighter lamp but never found one, maybe Carley?
