Someone asked me to design a simple high power driver for the SST-90 LED.
UPDATED 12-18-09
All parts are in house for 2 prototype builds, boards are on order, should be here by 12-22-09.
I will be on vacation starting the night of 12-22 through the holidays, so the first build wont be until maybe the last week of Dec.
The following are specs and options for this driver.
Size
The board is 1.2" in diameter by about 0.5" thick. I will fit in a "D" size Mag light.
The voltage input range is 6 volts to 24 volts. The board will not operate any lower than 6 volts because of gate drive issues with the mosfet.
The input is NOT reverse protected, care must be taken during hook up. This is mainly due to size and efficiency issues.
The input to the board is ESD and transient protected. The protection starts to conduct at about 28.9 volts, if you apply this it will damage that part.
The board it self is ESD sensitive, proper ESD handling procedures must be followed. Most LEDs are ESD sensitive also.
Low voltage drop out setting.
The board can be configured at time of order to turn off at a certain voltage. This is to protect the board and the batteries.
The default voltage that will be shipped is 10 volts.
No charge options for the voltage drop out are 6v, 10v, 11v, 12v, 13.1v, and 14v.
You must apply about 0.5 volts more than the drop out voltage for the driver to turn on.
Once on it will turn off when the input drops to the set voltage.
Other voltages can be custom set but may incur an additional charge for me to order more parts.
Output
This is a true constant current driver.
The user has some options when ordering for the current set points.
There are 2 connections on the board, shorting either to ground will select one of the current settings.
The user can order the following current settings 5, 6, 7, 8, 9, 10 amps on either selection.
So you can have 2 different drive currents.
The user could also hookup a user supplied 100K pot for linear dimming. You must specify you want to do this
at time of order and you can not use the switch method as above.
When ordering you must specify the forward voltage of the LED you plan to drive.
The design forward voltage is between 2 and 4 volts. If you want to work outside that range I can adjust the driver to do so on a special bases.
Driving voltages outside of the designed range could damage the board.
The board has output open protection if the LED where to open or become disconnected.
Should be able to start shipping sometime in January.
The cost will be $50
UPDATED 12-18-09
Size
Output
