You will want to add a resistor or I can adjust the trim resistor on the board for 84K. Having a lower value pot will just cause a lower drive current. You don't want to high of value, then it could over drive.
fppf,
can you put an edit line in the first post that reads something like
9amp driver fits M@g D
**(last revision as of Dec. 18) - design updates**
Input range x - xx volts -(you must provide battery information on ordering so components may be adjusted to set maximum and minimum voltage cut-off)
Output options: with x holes for x or x
-may attach pwm controller for ...
-can use x for x modes
-may attach a 100k potentiometer for ......
The driver will be able to do this just fine. However in this case I may need to change some other components out because of the lower drive current.
Let me get the first few built and then I will adjust the circuit for your needs. It may cost a few more bucks because I need to order some other parts. But it will drive just fine, the efficiency will be higher than the 9 amp 3.6 volt version as well.
That's great news!
I was mostly worried about my high battery input voltage: 25.2V
I'd like to re-wire the stock switch to change modes between 1Amp and 3Amps. Is that possble?
Another switch will go in the tail cap for actuall on-off duty.
Folks, the cut off voltage you use is based on your battery packs. If you look up the specs for your cells they will tell you what the minimum discharge voltage is. For Li Ion its typically 2.5 volts, for NiMH its typically 1 volt. Then just multiply that number by the number of cells you have. That will give you the lowest operating voltage of the pack without possible damage to the cells.
