Ok to answer the questions:
This is a true current source. It is a buck topology converter. There will be some ripple current but not much and it will be at a very high frequency. To make a converter handle this much current requires some larger components. All these components tend to be square in shape. So a round board is a little harder. I did some quick layout options and the smallest diameter I can go it 1.2" maybe a little bigger. I will work on that and let everyone know. Board coverage is already VERY high.
Efficiency should be somewhere between 80-90%. Its hard to calculate and until I build some and measure it that is as close as I can get. But I sacrificed a little efficiency for size.
I don't think I can get the price any lower. Because of the high current the cost of components goes up. Also building low quantities drives the prices higher and I don't plan on the demand being high enough to justify true production runs.
I think with some component changes we could drive at least 3 SST-90s in series.
Time frame has now been pushed out by needing a new board layout 😉
I will work on the new layout and let you know. The design is finished. Boards I get from a prototype house and take about 3 days to turn. All components are in stock at various suppliers and should take about a week to get here. Then I need to build and verify the design. Everything said and done we are most likely looking some time in Jan 2010.
I don't have any of these LEDs for testing. I'm just going to drive the power into a few power diodes I have that can generate the same Vf at that current for testing. There cheaper if I blow them up.
Hello Sir, would this heat-sink work(not melt the leds) for three SST-90 LEDS?
http://www.thermaltakeusa.com/Product.aspx?C=1152&ID=1586
OR THIS:
http://www.arctic-cooling.com/catalog/product_info.php?cPath=2_&mID=108
Thank you very much
[email protected]
