[ QUOTE ]
Aaron said:
I saw a post recently that talked about upgrading the bulb and batteries of the SL Stinger. Does anyone exactly what battery pack and bulb to use that works?
I have seen on E-Bay a battery pack that runs at 3600 Mah. Would this be effective with [/b]a WA[/b] or Ultra-Stinger bulb?
Thanks
[/ QUOTE ]
Aaron, it is helpful for discussion purposes if you supply a link to said battery. While IIRC, there is only one Ultra-Stinger bulb; there are a number of choices to choose from in the WA line, do you have a particular one in mind?
[ QUOTE ]
dano said:
Try a search...I don't have the exact threads off hand.
I'm the daddy of that, and I used 5 1/2-subC cells and an Ultrastinger bulb in a regular STinger body. Worked really well. Doesnt't work with a StingerXT, though...
--dan
[/ QUOTE ]
dano, can you be more specific about why it will not work with the Stinger XT(why tailcap impedes or prevents this?)
[ QUOTE ]
Ginseng said:
Right,
This mod goes way back to Dano's work. I recently built some 6V packs but they are relatively limited aside from the higher voltage. As Dano noted, they won't fit Stingers with a tactical tailcap switch. They also use 1.3Ah cells which will give you reduced runtimes, especially with higher powered bulbs. This last point is not so much a problem if you keep it on charger or use it sparingly.
There's just no way to get 3.6Ah into the Stinger stick and still pull 6V out. In fact, I've been toying with the only other way I know of to get that voltage out of that form factor: use 2 x CGR18650C lithium ion cells. These are unprotected 2.15Ah cells and are 65mm long. That is marginally longer than the 127mm of a stock pack but, of course, narrower. The Pila 168A would be too long I think. 2x67mm would put it 7mm overlong at 134mm.
Anyone want to be a guinea pig?
Wilkey
[/ QUOTE ]
I know Ginseng thinks out of the box, but there are other options for WA bulbs as he very well knows. Guinea pig? Well yeah, if I could just get some of the more unhelpful, know it alls, to provide details that are lacking in response to my Pila thread. Ummm, as I am sure most ppl know, Duracell 123 primaries are smaller in diameter than Energizer 123’s. That some AA NiMH(older Maha) are smaller in diameter than higher capacity AA NiMH, which may or may not fit in a 4toD adapter, inside of the Mag D size tubes. The Stinger might be one that I could work on, but I had another host in mind for the Pila. Are all 18650, exactly the same size down to the millimeter? One bare 18650 could be protected by one Pila, would that work(charging considerations aside)?
With limited runtime, loose cells can be changed out for a new set…assuming you are wise enough to buy a backup set.
Aaron, due to the complexity involved with taking apart a donor Stinger battery pack, for the proprietary contact pieces, Ginseng is no longer making these higher capacity packs available for purchase. You could PM him about the process however, if you are so inclined to experiment with battery pack building.
Mag UMP/Stinger feeler thread w/dano's comments
PM darkzero for his comments on the Stinger, as he has Ginseng's battery pack.
