I need a driver that can drive a string of fairly high voltage LEDs off of a battery pack, which could have voltage between 12 and 36 volts. I need to be able to drive two parallel LED strings, approximately 55v at 700mA, and the circuit also needs to be PWM dimmable at frequency of at least a few kilohertz.
I've been working on making my own driver based on Linear LTC3476. They have a design note that describes how it can be done, but even in simulation their circuit generates transient voltages in the kilovolts and can hardly manage the necessary current. I've been experimenting with some microprocessor based designs as well, but again the transients tend to kill the MCU.
I wonder if there is a commercially available driver and/or driver IC that can provide my required specifications. I have spent a lot of time searching and so far no luck.
Thanks for any suggestions.
