ohh, to bad, they cant handle the amps
check out the stickeys on the li-ion shootout thing in the stickey in this forum. then try to stay reasonable with the rate of discharge.
like if you can stay below 2C or 1/2 hour runtime, then the cells will last much longer.
but i know you wont
so you do get into heat issues and voltage depression from load that will disconnect it , trigger the built in protection and all, you know cause a thermal overload and blow the whole thing up, stuff like that
http://www.candlepowerforums.com/vb/showthread.php?t=117117
look for the 123 charts Here , in the li-ion thread for RCRs.
see the poor things cant even handle 2C very well. and you want to rate your 2C discharge rate off of the actual capacity of some 600-750ma not the claimed magic 900ma that none of them actually have.
So taking a wild stab at it, which is all i can do (due to cell differences), mabey about 2amps, then you blow up
i have some good RCR123s and they work ok at about 1.5amps , and about the max i would want to push the little suckers. i have some cheap ones , and they handle about 1amp just fine.
so use about 31 of them and drive that 110V ac halogen bulb at 100 watts
that should be what your looking for .
How bout 18650's? yes much better choice, handle a lot more power , have a lot more real capacity at even easy 5+ amp discharges.
for C and D sized li-ion they are more for better runtimes, than for more amps, a great 18650 would be the "best" choice for "amps vses size" , and there are more brands of them with high amperage protection curcuits .
so then it comes down to FIT, wedged into a D item :-(
3 of the rcr123s will fit in a Boored out D thing, or one that is big enough.
and 10 rcr123s would fit lengthwise into a 6D (i just checked).
so potentially you could get 30 (holy cow) wedged into a 6D , and really run a AC 50W halogen bulb. hmmm sounds crasy enough to try.
