HIVE McG converter used in the Aqua line of lights.
McGizmo
Maui
Hi guys,
This thread is intended for Rush (Martin) to introduce the HIVE McG converter and its parameters and options. Please wait for Rush to start the dialogue here. I am remaining ignorant on the means and method of programming this converter beyond "stock" for as long as I can and have no intention of becoming proficient to the point of offering a customized converter in addition to the stock offering. :duck:
rush
Germany
Hi folks,
This thread is going to be the place for all discussion about the new driver / converter, called HiveLD. Thank you Don for the introduction!
:wave:
As Don has pointed out, he is providing and supporting the driver in its stock configuration, anything going beyond this should be directed to this thread (for now). I will be actively moderating this thread to answer questions.
For all of you that want to make use of the ability to configure the driver, this will be the discussion ground!
The HiveLD Firmware
I am just going to give a quick summary of the possibilities that the setup mode of the driver is providing. For the complete documentation please see the web page that i have set up.
>> HiveLD Firmware Web page<<
This is obviously work in progress, i want to keep this web page as a central location for all information regarding the driver and update it regularly.
Basic concept of the setup mode
The setup mode works by visually signaling the settings and their value. You change the settings by turning off the light during certain time frames that are indicated visually as well. So there is no tools needed and you can load different settings on the go if you want.
The configuration settings include
  • Number of brightness levels
  • Each brightness level can configured individually
  • Use brightness level memory or not
  • Output current all brightness levels scale to (Default 1400 mA, hardware maximum 2200 mA for the HiveLD-P in the Aqua lights)
  • Threshold levels for the high temperature and low voltage output reduction
  • Three memory presets to store and recall a set of the above individual settings
archimedes
CONUS, top left
Very much looking forward to the details of this new driver, and particularly its programmability ... :)
Voltage range? Drive current? Overdischarge protection? :popcorn:
PoliceScannerMan
Gainesville,FL
Hearing this was the last push to submit my order. Being able to customize the driver is awesome. Low lows, good long running mediums, and bright hghs.
Speaking of which, what is the MAX current allowed to be programmed??
McGizmo
Maui
Anyone planning on getting one of these lights based on entering the custom programming realm should please wait until it is clear what is possible and how the programming works.
rush
Germany
Everybody,
Thank you for the feedback and questions so far :)
I have just updated my post above with more information and a link to a external web page that i will use as the main location for all documentation.
During the development of the driver i have compiled a manual that has become quite extensive. There certainly is a learning curve to using the setup mode of the drivers, but i am working on making things easy enough so this is not a problem for anybody interested. All your feedback will help improving the documentation!
The driver is providing a low voltage output reduction that also acts as a overdischarge protection. This means at the minimum cell voltage of Li-Ion rechargeables (about 2.7 V) the output will be turned off entirely, after it has been running on the lowest possible brightness level before.
So you can safely use unprotected cells with the driver, being it ICR or IMR.
Input voltage range for the driver is 2.5V to 5.5V, i. e. it is practically limited to one Li-Ion cell.
The maximum possible LED current that you can set is 2200 mA. But please be aware that the light will heat up quickly with such a high output, the over temperature output reduction will kick in soon under normal circumstances.
calflash
If (2) primaries are used, will the extra .5V be wasted as heat like some of Don's other lights or will the extra .5V cause damage?
rush
Germany
The 5.5 V is the upper allowed input voltage, for one component the absolute maximum is 6.0 V.
Lithium primaries have an open circuit voltage of 3.2 V when full.
So chances are high that you damage the driver using two primaries, yes.
ShineOnYouCrazyDiamond
CT, USA
Martin,
I have read through your website and this is an amazing driver. The flowchart of options is simply amazing. I must say this takes Don's lights to a whole new level than before and I hope to see this driver implemented in more of his offerings. An option that supports CR123/RCR123 would be a huge complement to the Makai and Haiku. I look forward to seeing the work you and Don do together over the next year or so.
I do have a question about the setup bridge. Is it required to keep the setup bridge in place if you want to be able to switch between the three Groups of settings?
kaichu dento
現在の世界
Very exciting project here and I hope that the low voltage cutoff will also be accompanied by a gradual reduction in output before cutoff is reached to both slow the onset of complete darkness and give due warning as well.
McGizmo
Maui
Martin,
As I understand, you can't enter setup without the bridge in place. When it is in place, you have to deviate from what I would consider normal use to enter setup but having had folks enter calibration mode on the 3S converter, I know this can happen. :shrug:
rush
Germany
Don is correct.
All the setup functionality (and this includes the three presets that you can use to conveniently store different configurations) is only active when the jumper pads on the PCB are closed. So if you intend to use the setup permanently, a solder bridge will work reliably.
Once unlocked with the hardware jumper, you have to execute this sequence of slower and faster On-Off cycles to enter the setup. From my own experience, this sequence is long and specific enough that you rarely get into the setup inadvertently.
The ability to store entire configurations in a preset lets you easily have totally different driver configurations that you can load in a few seconds. So after you have saved such a configuration in a preset you can turn the light from the stock configuration into one that for example has 2 output levels, no memory (always coming on with the first output level), and a high output of 2000 mA - whenever you need it and really quickly.
The low battery output reduction does indeed turn down the output in several steps before the cut-off voltage would be reached where it turns off the output completely. If you look at the lumens output graph from Dons' introduction to the Aqua lights, you see those reduction steps. The output reduction steps correspond to the voltage of the battery, i. e. the first reduction step happens at a certain voltage, the next one after another drop in the cell voltage. This means that the first drop gives you a low battery warning well before it would be totally discharged. On the lowest output level you would still have an hour runtime easily with an 18650 cell at that point.
I'm grateful for the positive comments about the drivers features and i hope that it will prove to be as good as you imagine once you are able to actually use it.
Please keep the feedback coming, any suggestions are welcome :)
gunga
Vancouver, BC, Canada
If I'm reading correctly, there are 21 levels at 100mA each, but what is the lowest low?
Also,what is the diameter of the driver?
hjdca
Los Angeles
Wow ! Great Driver ! Congrats ! Is it PWM or Constant Current ? Thanks for any info..
