Thank you for being so patient after all!
You already figured things out, but to reiterate for everybody else too, the values are signaled with blinks of different speeds, the blinks for the setting number are slightly slower than for the value of a setting. If any of these numbers is 10 or greater, then the digit for the tens (i. e. 1 in this case) is signaled with a quick double blink, not unlike the triple blink showing the beginning and end of the signal block.
Except for the double blink for numbers >= 10, all this is also illustrated in Fig. 2 of the manual.
You restore defaults by changing the value of setting 18 to "2".
When your light just went up to level 4 and couldn't be cycled any further you probably have changed the operation mode (setting 2) to "Volatile", which goes back to level 1 when you leave it switched off for more than the toggle period of half a second.
Hope you can enjoy your light now!
