supergravy
I am currently using a Hyperion EOS 606i hobby charger for all of my lithium charging needs. While this is proving to be a great charger, the documentation is very basic and apparently there are undocumented features.
The thing I want to better understand is charge termination and an undocumented "trickle-like" feature of my charger. This thing definitely follows the constant current / constant voltage algorithm - no problems. The thing that concerns me is that when I choose a charge current greater then 1A it terminates different then usual. It will do it's thing until the main charge is feeding 100mA or so and then beep that it is done. The different part is that it will then continue to apply small decreasing current all the way down to 5mA or so before truly shutting down. If my initial charge rate is less then 1A, it shuts completely down at 100mA as documented.
This appears to actually be a nice feature and something similar to what the Duratrax ICE charger does. The difference is that the ICE does it with all charge rates AND it always shuts things totally down at 30mA.
Here is my concern. This additional charge time from 100mA down to 5mA or so can take a long time. While it never allows the battery to go over 4.2V, it does mean the battery is hooked up and taking current a long time. The last bit from 30mA and below goes forever - I can see why the ICE stops at 30mA as it seems like a good compromise.
Is there any harm in this extended charge? It does seem to put every last bit into the battery. If I take a battery off the charger when the main charge (100mA or better) ends it will quickly drop down to 4.17V. If instead I let the thing go full cycle to the very end, I find my batteries hold 4.2V even with hours of rest.
Appreciate any help from you charging guru's out there!
