andersonEE
So last week I built a light fixture for my hallway with a 930lm warm white Bridgelux LED powered by a 15W dimmable driver from Roal Electronics. The new light replaces a 75Watt incandescent bulb in an ugly globe fixture. Here are the Pics:
The opening in the ceiling where the old fixture used to be:
3 Foot length of 1/8" aluminum bar used for heatsinking. You can see the old globe fixture in the top left corner.
One end of the bars I scuffed with sand paper to help with heat dissipation.
A repurposed computer heatsink will be the LED mount. Here it is being prepared for drilling.
I tapped the holes with #4-40 threads.
ArctiClean works great for removing old thermal paste and prepping new surfaces.
And here is the LED, with contacts pre-tinned.
ArcticSilver Ceramique used between the led and heatsink with screws keeping pressure. (Not my first choice, but I had it laying around.)
ArcticAlumina and screws to attach the aluminum bar to the heatsink.
From the Attic, the mounting.
And finally, the control shot with light off.
And with the light on (haven't installed the dimmer switch yet).
And
The warm white is perfect. It seems alot like sunlight. It is also very bright...much brighter than the 75 Watt it replaced. We'll see how bright it is after I install the frosted glass beneath it.
I had tested this LED just with the computer heatsink alone (no bars) and it got very hot after 30 minutes or so. With the vertical bars, it barely gets warm after hours of running.
I still have much to do (frosted glass fixture, sealing around the opening with caulk, dimmer, etc) so I'll post more pics when I'm done. I'll post the electrical characteristics too.
And
Haha, I know that's not much but the led and driver are both rated for >50,000 hours so I will definitely make the money back. Total cost for this project was ~$75 dollars including shipping.
