qwertyydude
- Joined
- Aug 10, 2008
- Messages
- 1,115
I didn't know where to post this but if you ever need to make heat sink epoxy, which I needed for some projects of mine, a good way is to use a sanding drum and sand a block of copper. I used a fine 320 grit drum on my dremel. And using light pressure I sanded a small block into a pile of dust. To make the regular 5 minute epoxy as heat conductive as possible I mixed as much copper dust as possible into 5 minute epoxy as to saturate it into a thick almost non adhesive paste. Applying this as thinly as possible and wringing the two objects to squeeze out air and excess epoxy and applying pressure until dry resulted in the led star making incredible thermal contact with the heat sink plate.
For comparison I used a regulated, overdriven 1.4 amp R2 led on a star. This is attached to a black anodized heatsink with the anodizing sanded off the base where it makes contact. I maxed out the test at 130 degrees. The artic silver epoxy reaches 130 degrees in about 3:30 minutes, my custom mix reached it in about 3:10 minutes. I'd say a significant improvement.
Now this is only good for non electronic uses because this stuff is actually conductive, I measured a direct ground from the star to the heatsink base. But since it is electrically conductive you know it has to be a nearly ideal heat conductor since it is made of copper. It's got to be at least as effective as soldering for heat conduction. Plus it is really really cheap to make. So if anyone is interested here's a cheap way to heatsink stuff.
