JimmyM
Test conditions: 20V in, 12VRMS out, 64625 bulb.
This is the OFF transition (voltage measured across the FET)
10V/div, 5uS/div
Green = FET Driver with 510 Ohm resistor in series with gate
Pink = AVR direct drive with 68 Ohm resistor in series with gate.
This is the ON transition (voltage measured across the FET)
10V/div, 5uS/div
I know the FET Driver has a 510 Ohm resistor in series, but the AVR with the 68 Ohm resistor (calculated in Dev thread) shows a nice drive (slew rate-wise) , but the voltage spike at turn off holds at the "kick voltage" for longer.
I'm going to turn things up a bit and see what happens.
10V/div, 5uS/div
10V/div, 5uS/div
