How close is close enough for matched Nimh capacities?
Niconical
Spain
When I first started to write this, it was query about termination on one of my Maha C9000 chargers, a question about another, then some more, some tests that I've been doing for weeks, and it all got too boring.
So, I'm going to (hopefully) address all my concerns with this simple question.
How close is close enough when it comes to matching nimh batteries?
For example, a set of 4xAA batteries.
2000mah / 2000mah / 2000mah / 1000mah, obviously not matched.
2000mah / 2000 mah / 2000mah / 1990mah - let's call that a matched set of 4.
So where is the line, what percentage or mah difference from highest to lowest is acceptable to consider it a matched set?
Thank you
2000mah / 2000 mah / 200mah / 1990mah - let's call that a matched set of 4.
My guess the 200 was a typo.
Short answer 10%
How close they need to be depends on how deep you will be discharging them and how well they they stay matched (voltage wise) if rather severly overdischarged.
Most consumer electronics will shut down when the battery reach approx. 1.1 volt per cell so no problem. Some LED flashlights will drain them to a very low level. The only real problem is if(when) one cell goes to zero and then the other cells will reverse charge it. The more cells in series the more likely this can happen.
As a test I discharge two AAs to 0.9V on MahaC-900 @ 500 mAh rate. I then repeated using 200 mAh rate. I then placed them in a TerraLux 220EX and they maintained decent output on high for 20 minutes,at 25 min. I could not tell any difference between Hi and low but I left set on high and after 40 min. total the light was getting fairly dim. I would guess approx. 20 lumens (based on other lights ratings). When I stopped the test one cell was 0.9V and the other 1.12V.
Charles
Thank you for the answers.
I can't give any specific details at the moment, final testing is ongoing, but this is how it all started.
To cut a long story short, it seemed like the first slot on the left on my Maha C9000 was charging less than the other 3 slots. I tested it repeatedly with different sets of batteries, and also before testing each set I would confirm (as best I could) that they matched.
My test tonight has been to fully charge 4xAA eneloops in different chargers. I'm pretty sure these are good sets. Discharged at 1000ma the 4 capacities were 1866, 1864, 1865, 1868.
I will now charge them. Although the amount of charge they take does not of course indicate the capacity, you would expect the 4 numbers to be similar, just like the discharged values. However, based on previous tests, I would guess that slot 1 will be 10 or more % lower than the other 3 slots. I will leave them in a while after each slot says 'done', then discharge at 1000ma. If I get a significantly lower discharged capacity in slot 1, does that mean I do indeed have a faulty slot 1, seeing as I have previously confirmed the capacities at 1amp (1866, 1864, 1865, 1868) or am I missing something?
I have both a LaCross BC-900 and a Maha C-9000 and I find it normal for cell capacities to vary from charge to charge and slot to slot. Using only the two outside slot helps as the cells stay cooler.
Take the cells from normal service,stick them in the charger set to discharge and see how much capacity remains. I often see cells that reach 0.9 volts while others are stil at 1.1 plus.
Closely matched cells are only needed if you are using them in high cell count series connections and deeply discharging them.
I fly RC aircraft and use 8 NiMH cells in series in my transmitters. They get recharged when the display reads 9.3-9.6 volts under a 250mAh load in most transmitters and under a 140 mA load in one. I never worry about matching cells closer than 10%. The difference between a 1500 and 1700 useable capacity cell just does not matter.
As I have often advise if you must have 100% capacity from 2000 mAh cells then use 2500 mAh cells instead and use only 80% or 2000 .
I have a matched 6 cell NiMH R/C car battery pack. Due to the shrink wrap, I can only see the labels on four of the cells.
All four have a discharge time of 415 seconds at a rate of 30 amps, for all four of the cells to reach a voltage of 1.171 volts. All four have different peak voltages, however: 1.494, 1.484, 1.498, and 1.505.
Note that this pack was purchased over 3 years ago and was a "mid level" matched pack of GP 3300 cells.
Take from that what you may.
Short answer 10%
I strive for 5%, but live with 10%.
Tom
Harding:
"Matching refers to the grouping of individual NiMH cells with similar capacities to be used within a
battery pack. Typically, the matching of the cells in a battery pack is within 2%."
Thread resurrection, but I'm hoping to get some help.
This may be a dumb question, but I just can't wrap my head around something this sluggish Sunday morning. When we're talking about using % to set matched capacity limits, are we talking about using % from nominal? Or are we talking about % from a mean of observed capacities from a set you're looking to match, or some other calculation?
For example, I broke in 8 of my older Eneloops on my Maha C9000 and recorded the following for each individual cell (I set to 1900 mAh):
1) 1918
2) 1911
3) 1905
4) 1913
5) 1946
6) 1942
7) 1957
8) 1965
2% from 1900 mAh yields 38 mAh and provides a range of 1862 - 1938 mAh. So cells #1-4 I could mix in use as needed. Cells #5-8 are over the 2% nominal limit, so I couldn't mix them with cells #1-4, yet they have a %CV of 0.54 and would seem to me fine to use in series. Thus my question: If you have cells that are over or under 2% of the nominal, how do you identify outliers from a batch? How am I supposed to calculate the 2-10% match limit?
Thanks!
Thread resurrection, but I'm hoping to get some help.<snip>
Well, not sure I can help, but I enjoyed reading this "resurrected" thread. Since I didn't post any of the old posts, I cannot say for certain what they mean, but I can tell you what I "think" (for what that's worth). I hope that others who are more knowledgeable will also chime in.
You likely already know this, but as I understand it, the issue with matching cells is closely related to usage. Serious discussion of matched battery packs seems to center on the RC racing world. When racing a small electric car, the ability of your battery pack to drain every possible drop of energy can mean a few extra seconds of runtime which can make the difference between winning or losing a race.
Therefore, in the RC racing world, the closer your cells are matched the better. Serious racers are looking for the highest possible capacity cells that have (if possible) 0% capacity difference between them. As I understand it, having one cell of lower capacity than the others causes the other remaining cells to attempt to recharge the dead cell, and this can both damage cells and greatly reduce performance.
When we're talking about using % to set matched capacity limits, are we talking about using % from nominal? Or are we talking about % from a mean of observed capacities from a set you're looking to match, or some other calculation?<snip>
Since the "ultimate" is having 0% difference in capacity, I am not at all certain that there is any agreed on method to arriving at "% to set matched capacity limits." If it were me, I think I would take the difference between the highest capacity cell and the lowest capacity cell and divide by the lowest capacity.
1) 1918
2) 1911
3) 1905
4) 1913
5) 1946
6) 1942
7) 1957
8) 1965
Assuming you were going use the first four cells as a matched set: (1918-1905)/1905 = 0.68%
2% from 1900 mAh yields 38 mAh and provides a range of 1862 - 1938 mAh. So cells #1-4 I could mix in use as needed. Cells #5-8 are over the 2% nominal limit, so I couldn't mix them with cells #1-4, yet they have a %CV of 0.54 and would seem to me fine to use in series. Thus my question: If you have cells that are over or under 2% of the nominal, how do you identify outliers from a batch? How am I supposed to calculate the 2-10% match limit?<snip>
Outside the RC racing world, I think the issue is how best to group the cells that you already have, in order to produce the best possible set that you can. (True "outliers" both higher capacity and lower capacity can be relegated to single cell application.)
But, the need for well or "better" matched sets, depends a lot on how you are going to be using those sets. As I understand it, having better sets mean that you will do less damage to the cells should you ever run them "completely" dead. Therefore, if you tend to change your cells before they are "completely" dead, I think having extremely closely matched cells is much less of an issue. If you know you have (or might have) a very poorly matched set in use, try not to run them down too far before recharging.
But, personally, I figure I may as well try to select the best possible sets, when I can. Obviously, the more cells you have to chose from the better. The last time I purchased Eneloop AAAs I purchased 5 x 4 packs, so that I had 20 cells to work with.
It takes "a bit" of time (understatement), but I use my Maha MH-C9000 to run a discharge, break-in, discharge, and analysis. Then, I use the final "analyze" capacity readings to determine my groups. It can be rather mind numbing to look at all the capacity figures and try to determine "which one is most like the other one." So, since I enter all my data into an Excel spreadsheet anyway, I have come up with the following method to "enhance" (make more obvious) the slight capacity differences found in most Eneloop cells:
Using the capacities of your 8 cells, the green area shows the "enhanced" differences. Clearly, given these 8 cells, if your desire was to create two matched sets of 4 cells each, you would want to use the first 4 cells (all negative %) as one group, and the last 4 cells (all positive %) as the other group.
The more cells you have and the closer they are in capacity, the harder and harder it becomes to "decide" which cells to group together. So, I find the above method works well for me. It is also quite simple (if you use Excel). The formulas used in calculation are shown on the right. The idea is to subtract the measured capacity from the rated capacity, to arrive at the "difference" for each cell. Then you average those "difference" values, and you take the standard deviation of those "difference" values. Finally, you take the "difference" value for each cell, subtract the standard deviation, and divide by the average. The resulting "enhanced" difference percentage does not "care" at all about the performance of the cell in relation to its rated capacity, it only "looks at" the differences between cells.
Don't know if any of this has helped you or not. But, I enjoyed writing it. Hopefully, others will join in to both critique my methods, and offer better advice to you.
Hello HikingMano,
Since you provided some capacities let's go with what you have.
Your average capacity is about 1932 mAh with a standard deviation of about 23 mAh.
Comparing the cell with the least capacity (1905 mAh) with the average we come up with a difference of about 1.4%. Likewise comparing the cell with the most capacity (1965 mAh) with the average we come up with a difference of about 1.7%.
If your matching criteria is 5% you are good to go. If you have a tighter criteria of 2% you are still good to go.
You can tighten things up by sorting the cells and let's say you are interested in using 4 cells in series. By eliminating the 2 cells with the lowest capacity and also eliminating the 2 cells with the highest capacity you end up with an average of about 1929 mAh and a standard deviation of about 16 mAh.
Looking that the new lowest capacity cell (1913 mAh) and comparing that to the new average we come up with a difference of about 0.8%. Looking at the new highest capacity cell (1946 mAh) with the new average we come up with a difference of about 0.9%.
This would give you a very good set of matched cells.
Tom
For basic stuff like clocks i don't mind 100mAh difference but for anything else including flashlights i like to try to have the cells within 50mAh of each other. Usually i'll get the bigger packs of Eneloops. Like the 12-16 pack of AA cells and the 8-12 pack of AAA cells, that way i can test them all out and group them together. My Eneloop sets in general are pretty even and are within the 50mAh range. I made the mistake of not writing down one set but they had about 60mAh difference and was used in a Portapow USB charging device which tends to drain one cell more than the others so i most likely had that difference spread out for that reason. It's a good thing to at least note the capacities so you can be careful not to run the cells all the way empty which will also extend the life of the cells.
RC cars and other motorized stuff (power drills and what not) i'd like to buy a 16 pack of Eneloops and group the best ones while refreshing the cells to their peak capacities so they are all within 10-30mAh difference in case for some reason or another i end up draining them out or if there's an excess amount of power being used at once (like if the RC car got caught up on a rug, dirt rocks, ect and the car is pulling more energy out of the cells).
Thanks guys, your answers make sense :thumbup: Much of my NiMH use is in single cell lights, but I do have a light or two that run on 2-4; so since I recently picked up a C9000, I've been breaking in all my batteries and working on matching capacities for flashlight sets for the known reasons. Rosoku, sometimes I run my larger 4xAA requiring lights down while out playing outside at night before swapping for a fresh set, so my goal is definitely creating the best matched sets I can. I agree on relegating higher or lower capacity outliers to single cell applications.
Ok, so it looks like we are indeed comparing amongst the cells and not to nominal capacity, i.e.:
Rosoku, in your method, how do you determine what's "good enough" to group? For example, how would you decide if it's ok to match two cells with an "enhanced difference percentage" of 40% vs. 200%? What if we just used something like a Levey-Jennings chart to exclude out-of-limit capacities?
Thank you, Tom, makes sense :thumbup: That's more or less how I had one version of my Excel workbook set up.
You both answered my question (comparing to mean measured capacity, not nominal capacity), thanks!
