you first got to understand the base type of the halogen lamp. it might be an H3 or H7.
Once you got that info, you have to ask yourself if it has got a 12V SLA battery or just 6V SLA battery.
If it has got a 12V battery, then you're good to go with a common chinese automotive HID kit - you can choose 35W or 55W, basically they have the same bulbs just with a different ballast.
you got to pick up a hid bulb with the correct base - the same of your actual halogen bulb (H3 or H7), and also choose your prefered color temperature - I think that here on CPF we all agree to go on the 4300K temp, max 5000K.
Once you have the HID kit, you just need to open up the light, remove the old halogen bulb and replace it with the HID kit.
In both cases, even if you have a H3 bulb or H7 bulb, you'll have to connect the RED (+) and BLACK (-) wires coming out from the battery/switch to the two pins coming out of the HID bulb. At the same time, you'll have to connect the HID bulb to the ballast. For this there are usually 3 connectors: two small connectors similar in shape and circular, and one bigger connector that goes directly to the ballast.
Finally, you need to find the space to put the ballast. I doubt, by looking at your picture, that you have still space inside the body to put the ballast, so my suggestion is to put it under the body (external), by removing the base plate of the spotlight and put the ballast at his place.
In this case you want to dig some holes in the body/head to let the wires pass through.
any HID kit on E-Bay will do the job, as long as you are sure to pick up one that has H3 bulbs.
A 55W ballast is quite big and thick, I mean it is minimum 80x70x30 .
I already swapped out the 55 watt for a 100 watt bulb....does not seem to be that big a difference?
Might have something to do with the shape of the reflector.I have the HID version of this light and it can't compete with my POB in the throw department.Spotlights with flat bottom reflectors don't seem to perform very well.
If I get a chance latter I will pull it out of the trunk of my car and try to dismantle it.That frosted bulb doesn't really clean up the beam.Still lots of artifacts.But considering that I paid around $50 for it I can't complain.A good HID for the money.
I just finished completely dismantling and reassembling this light-sorry-no photos yet.If you remove the 5 screws at the rear you will see the battery.Pull out and unplug the battery.You will see an empty space under the battery tray(the belly section of the light).This is where the ballast sits.It is next to impossible(at least for me)to get the ballast out-so I didn't even try!!!!
Since it appears to be a propriety type ballast designed for this light I'm not sure any other ballast will fit in there.I might be wrong but I wouldn't attempt it unless I could afford to make this mistake or figure out another way to mount the ballast.
It's ten times easier pulling the ballast out from the front.
Reducing the amount of frost on the bulb's envelope with polishing compound and a Dremel rotary tool helps improve the beam but not as much as you might think.
That spotlight is making a strong chemical smell....I opened up the back and looked at the battery....it was not leaking or anything....I took it and sat it out in the pole barn...es stinken.
Thanks for the tip-I might give it a try.:twothumbs
I would be mildly concerned about any strange smell.Might be coming from the ballast or battery.Maybe one of the HID or battery gurus around here could jump in and offer some advice or warning.
Can you describe the smell? Sweet?
Then it is either the casing (synthetic materials) or a leaking battery. I'm guessing it's the former. SLA hardly do leak and they are quite hardy.No....not really....never smelled anything like it before:thinking:
It has a rubber or weather proof coating on the bezel....I thought it might be coming from that.....but the smell is everywhere on it and was permeating the dinning room so it got chucked out in the pole barn...its a nice looking light but the smell is pretty strong....can a charged battery give off a chemical smell?
The Stanley and POB do not give off a smell.
