I have no experience on A2, but be careful with this, isn't the A2 battery tube made of electrically conductive aluminium? If it is, you are shorting the other one of the batteries (the one closer to the tailcap) because the battery case is directly connected to the battery minus.MedusaOblongata said:...Before I put the new batteries in, I removed the plastic shrink wrap, and they slid in and out easily enough. ...
MedusaOblongata said:Ok, finally got them out. I tried supergluing a paper clip to the exposed bottom of one battery, but the glue wasn't strong enough and it just pulled off. So I slammed it against the side of the counter until the counter broke, then slammed it against the side of the workbench until it came out about 1/4", just enough to get pliers around, and pulled it out that way. The second battery came out a little bit easier. Before I put the new batteries in, I removed the plastic shrink wrap, and they slid in and out easily enough.
Thanks for the help, guys.
I hope nobody tries to pour warm water over one after reading this thread. You don't wanna get too much water near lithium batteries.
chesterqw said:tie a rope to that light then go to a open field/space with no one at all.
swing the light around you like you are the sun and the light is earth.
hopefully, the batteries will come flying out.
Alin10123 said:eeer...
Didn't that dent up a brand new shiny light?
MedusaOblongata said:It was a Titanium 2 battery pack, with the shrinkwrap around it, so what I removed was not an integral part of the batteries' insulation.
greenLED said:Prof, AmondoTech "matches" their cells like that. The shrink-wrap goes on top of their label wrap.
