Alin10123
AndyTiedye said:Too bad about the counter. That might actually cost more to fix than the Surefire is worth.
LOL i was thinking the same thing!
but oh well... he probably thinks the SF is more important. lol
R11GS said:Old school stuff. I think folks are close, but mix it up. Freeze the thing overnight (everything shrinks), run under *hot* water long enough to get the torch gutenhot (torch expands, battery still cold and shrunk). Do the wrist flick thing. If that doesn't do it...
Then as batteries can sometimes do, it has most likely swelled. A gob of JB weld with a paper clip on the end just might do the trick. I've seen people extract bolts that have had their heads shear off simply by JB welding another bolt to the broken one.
Good luck.
