shane45_1911
OK, sounds sort of like a noob question at first , but...
If I am running pair of AA 'loops in my Fenix LD20 (for example), and I don't want to run the risk of reverse polarizing a battery - how do I know when the batteries are getting low - without getting too compulsive like keeping a log of useage time.
Since the LD20 does not have a "low battery warning", and has several different output levels - it is not as easy as simply noticing a drop in lumens.
If I was constantly using the light at one constant output setting, I would be able to notice a decrease in brightness - but I am not.
Is it as simple as assuming the light will no longer go into turbo mode, for example, if the batteries are too low? I assume it still would with constant regulation, however?
