filibuster
- Joined
- Dec 27, 2005
- Messages
- 205
I found eight Amondotech Titanium 850 AAA NiMh batteries in my closet the other day. They are about three or four years old still in their original four pack shrink wrap.
I split one set apart and stuck them in my Maha MH-C9000 charger and did a break-in charge but after it finished the cycle the batteries only registered 350-380 mah. I next performed a 3 cycle charge discharge test but even after that the four batteries ended between 450-500 mah. A little improvement but still a long way from rated capacity.
Will continued cycling restore the batteries capacity or is long storage without use the death knell of a NiMH battery?
Can you jolt a cell back to good form by using a high charge rate or a high discharge rate or is it better to do many low charge and discharge to try and persuade the capacity back into the cells?
