What is the correct way to check a 123?
I have some that I took out of my 6P when they got weak. They got mixed in with some good ones and some half used ones (not by me).
If I check them on a normal digital meter, they all show 2.7 to 2.95 volts or so, whether they are new, half used, or the weak ones.
If I check them on a Micranta (radio shack) battery tester (I assume it puts a load on them), some show good, some show dead, some in between. Even the dead ones per the battery checker still show 2.65 volts on the digital meter.
Often alkaline batteries that show good on the battery tester are weak when put in a light.
So....what's the correct way to check batteries?
How do you guys that are always doing run tests, reviews, and so forth get your battery voltage numbers?
tia
tia
