[ QUOTE ]
BuddTX said:
[ QUOTE ]
Brotherscrim said:
Compared to the standard bulb, my eyeballs tell me it's definately brighter. At the hotspot, the EverLED is a bit brighter than the stock bulb, no more than twice. But it has a big corona that is no less than 1/2 as bright as the hotspot, so the total output is definately much greater than the Mag stock bulb. This is on a 4D Mag with new batteries and under 30 minutes of wear on the original bulb.
[/ QUOTE ]
Now, I know that the light will be "WHITER", but how does it compare to the "throw" of a 4D Mag-lite, with a stock bulb? (assuming the ever-led is also in a mag D light?)
[/ QUOTE ]
Like I said, it's brighter. "Throw" is really a question of focusing. And as the second paragraph of the post you quoted says, the EverLED focuses very well. I live in a city, so the opportunity to test throw is limited by light pollution and respect for neighbors. But I can honestly say that in my experience, an EverLED in a 4D mag will meet or beat the stock bulb in every way. It's brighter, whiter, and I would imagine throws just as far.
Now, I have just had the chance to put the EverLED in a Tec 20. This is not a good set up. The EverLED is a little too tall, and you wind up with the black "collar" of the EverLED fully in the reflector. Combine that with the much smaller reflector area of the EverLED compared to the Mags, and you wind up with a couple of problems.
The hot spot is a bit dim, and a fair amount of the light winds up going all over the place.
Also, because the EverLED is so much longer than the standard bulb, you can't screw the bezel on very far. The bezel barely passes the O-ring, making me wonder whether it can still keep the water out. Even when I snipped half of the spring off, it didn't really help all that much.
