TheGeekInTroy
- Joined
- Jun 21, 2008
- Messages
- 11
What measurement is used to determine the brightness of a single led?
What is the electrical limit of an LED as far as lumens go. For example, if you pump so much ma's into and set of LEDs, will they "explode"? In other words, does the amount of lumens have some bearing on wear and tear. Can you wear down an LED faster by pumping more electrical current into it. The answer I would assume would obviously be yes, but how much?
I feel I should add that hot/overdriven LEDs are not subject to shock/vibration problems like incandescent bulbs.Well let's look at that from the surefire P60 perspective since it's very easy to do so. Instead of looking directly at wattages we'll use light output (lumens), since I'm too lazy to figure out just how much wattage a P60 draws. With the latest emitters and an efficient driver circuit, a 60 lumen P60 LED can be run in regulation (non dimming) for about 8 hours. A 60 lumen P60 incandecent will run approximately 1 hour, half of which is spent below 60 lumens.
As far as time to failure/burnout, a P60 incan will last between 25 and 50 hours on average, the hottest overdriven LEDs can last at least 500, and most are a bit better than that. As leds increase in efficiency towards 100% electricity>photon conversion the reduction in heat will allow them to last much longer, perhaps even as long as the old "100,000 hour" manufacturer claim when LEDs were becoming popular. If both are driven to say, 10 watts in a P60 type assembly, assuming the LED is heatsinked properly and a xenon lamp incan. you run into problems for both of them.
A 10 watt LED in a small handheld light is putting out ALOT of heat, if it doesn't go somewhere then it will severely shorten the life of the LED, by how much depends on how bad the overheating is and how well that particular LED handles temperatures. If you can take care of the heat by using a larger flashlight body or more efficient LED you're looking at 1000's of hours before failure. The incandecent will still have a roughly 30 hour bulb life but due to its construction is more prone to failure via shocks or vibration.
