How Do You Return Gmail to Basic HTML Permanently?
brembo
The issue has been narrowed down to a setting within GMail itself, multiple browsers and operating systems were tried. Settings were also compared closely and total emulation of the known working settings did not bring about the desired change.
To change GMail to the HTML set all that is needed is to add /h/ to the link, but it's just a stylesheet of sorts and does not modify the universal(login) settings. Anyone know of a radio-button or hidden setting that needs to be changed to make this a permanent change?
LEDAdd1ct
Hudson Valley
The following two threads show individuals similarly frustrated:
One
Two
In addition to Firefox, Opera, Chrome, and IE 6 not producing the "Set basic HTML as default view" link at the top of the screen, booting a computer with Slax, an entirely different operating system, and running both Firefox and Konqueror produce the same result. I am convinced that someone at Google is either nuts, or, my account is possessed.
On a positive note, I spent 40 minutes on the phone with Mr. brembo, and he is a gentleman.
EDIT: I created a junk mail account and sent the user name and password to brembo via PM. He was able to view the coveted link at the top, and permanently set the junk account to basic HTML. I was not.
I pulled out an old laptop with K-Meleon and Firefox 3.0b2. I plugged in the phone cord, and used an old dial-up account, thinking that perhaps switching ISPs would help. When I tried to log in to my account, I could not view the link to make basic HTML permanent. When I entered the junk account, it was as brembo set it, with basic HTML as default.
Different browsers, different operating systems, different computers, different ISPs...no change.
LEDAdd1ct
Hudson Valley
Yes, that is what I have been doing, typing it in manually each time. It is very annoying.
I cannot understand what would motivate Google to remove the link allowing you to set Basic HTML permanently.
Why do they care?
Hopefully, they will add back the link.
nbp
Wisconsin
When I punch in my username and password and hit login, for the moments it takes to log in, I have a link show up to tell it to show in HTML format. I don't know if it is permanent, but it might be an easy workaround. One extra click in the login process.
LEDAdd1ct
Hudson Valley
Yes, that is true. The link pops up for anywhere from a split second to twenty or more seconds if you are on dial-up, in which case it will prompt you to switch to Basic HTML. Unfortunately, that link is also not permanent.
It's a good suggestion, though, and it is worth mentioning and keeping in this thread for reference. :)
TooManyGizmos
Died Nov. 2015
Check in your Computer's /Control Panel/Internet options/Advanced Tab ......
are there any relevant settings there about HTML operation and/or defaults ?
Also you should Google search ... "Gmail HTML"
I found several Help links there about the options for Gmail .
LEDAdd1ct
Hudson Valley
Hi, TMG. :)
1) It has nothing to do with one's computer. I've tried different machines, four physical and one virtual, as well as accepted brembo's help. He logged into my account from his machine hundreds of miles away with no difference.
2) Before starting this thread, I searched Google until there were no more pages to search—I went to the end of all relevant (and many, many irrelevant) search results. All "solutions" involve either changing a setting (which I cannot see on my account) or using a different URL to log in (a workaround).
It is endemic to the account itself. :(
TooManyGizmos
Died Nov. 2015
Sorry I couldn't be of help to ya Add1ct .....
I wish I knew more about it so I could offer you a solution .
I guess it does no good to change your Google Mailbox Bookmark to this ...
http://mail.google.com/mail/h/.
That takes me to a "basic HTML" page with a choice box at the bottom.
I do wish you luck and success in your attempts .......... TMG
LEDAdd1ct
Hudson Valley
The Gmail gods must be smiling down upon me:
I am on a really slow wifi hotspot, and it asked if I wanted to view as Basic HTML because it was loading at a snail's pace. I said yes. I had used my old dial-up connection to make things load very slowly several times before to provoke the same result. The past billion times I clicked the link, though it did take me to Basic HTML view, it did not offer to make the change permanent, as my default view.
This time it did!
Why did it work this time? I have no idea. But hopefully, for other people who are having this problem, the answer is that you might get lucky, and be offered the link if you try loading Gmail in a different location. I cannot think of anything else.
MojaveMoon07
U.S.
I have two ideas.
In Firefox when I use a larger minimum font size, sometimes a link or a button on the website does not appear and is inaccessible until I reduce the minimum font size.
If you use Adblock Plus or NoScript, sometimes I have had to temporarily turn either one of them or both of them off in order for a link or a button on the website to either appear or be accessible.
tools -> options -> content -> font & colors: advanced -> minimum font size
LEDAdd1ct
Hudson Valley
Well, it's been a year now, and everything is just fine.
Thanks for the posts, guys. It is/was not a font issue, as different browsers, different operating systems, and different versions of different operating systems made no difference.
This thread is the sixth hit on Google when searching "gmail basic html" so I hope that the potential solutions listed here continue to help others who are as aggravated as I was a year ago.
Minni
I know this thread is years old, but I found it via keyword search & my case is relevant to the OP's. So i'm weighing in just for the record. (Been a long time since I was las here.)
I've been trying out a new Win-10 laptop that's higher speed than my previous XP and Win7 laptops.
On my XP and Win7 laptops, I was using Firefox.
But this Win10 system came with MS Edge, and I didn't download FF yet, since i'm still trying out the laptop.
Frankly, I'm unsure if the defective HTML-view issue (in my case) is related to my using the Edge browser vs. firefox,
...or else related to my "upgrade" to Win-10.
In the past, during login, during the brief period that Gmail flashed the blue-link enabling the switch to HTML view, the switch was successful, BUT NEVER PERMANENT (even if successful at every login).
But now, EVEN THOUGH that blue-link still displays, and EVEN THOUGH I RUSH to click on it (due to my speedier Win10-MS-Edge)…
...it still directs me to their horrible standard view. I absolutely HATE standard-view, which doesn't enable me to control it, rather it controls me, and is NOT intuitive. I hate composing emails via standard view & so on and so forth.
LEDAdd1ct
Hudson Valley
Hi, all.
I want to offer a ten year update to this thread.
Either because of a behavior on my part, perhaps clicking something that sent GMail into "standard" mode, or, something on Google's end, the account setting once more got tweaked, and my account is no longer permanently set to Basic HTML mode.
The other popular hacks widely documented across the Internet are still valid:
1) Bookmark this URL
https://mail.google.com/mail/h
2) Disable JavaScript
etc...
—but they do not permanently restore Basic HTML to the default view at the account level.
I don't understand what possible benefit removing this choice could confer.
I prefer the dynamic, modern, "new" version for emails at my work Google email account, because of the auto-update feature, presence feature, etc., but *much* prefer the Basic HTML version for my personal Google email account.
Has Google permanently removed the ability to set Basic HTML as the default view?
It appears that way. :-(
