Chris M.
Power (watts) = Voltage (volts) x Current (amps).
Power dissipated in your resistors = Voltage dropped accross them (ie, input voltage - voltage accross the LS) x current.
So if your supply is 4.5 volts, the power dissipated in the resistors is (4.5- 2.95) x 0.324 = 0.5 watts (to 2 decimal places).
Higher power resistors won`t necessarily be cooler, they will just be better able to withstand the heat generated. Larger physical sized ones will be cooler to the touch cos there is more of a mass to heat up- but still, they`ll be just as warm overall- as there`s the same amount of power to dissipate in them. It`s just spread out over a larger area.
Any help?
Any help?
