How long does it take to change up
Albinoni1967
On average assume if if I charge up a flat 18650 battery how long does it take. Would you say 1, 2 or 3 hours.
MBentz
Folsom, CA
Depends on the battery and the charger. If your charger charges at 1 amp and you have a 3000 mAh battery, it will take three hours.
If your charge rate is .25 amps and you're charging a 2000 mAh battery, it will take eight hours.
Albinoni1967
Ok I'm getting a Xtar VP1 charger and my batteries are 3400mAh, but I'm not sure what rate the VP1 charges at.
Curious_character
Sorry, it doesn't work that way for Li-ion batteries. The constant current is delivered only until the cell voltage reaches 4.2. After that, the charge current slowly drops. The cell isn't fully charged until the current drops to a very low value. It typically takes about 3 hours to fully charge a Li-ion cell at 1C. That is, a 1 amp charger takes about 3 hours to fully charge a 1 Ah cell.
This is the standard charge algorithm, but not all chargers follow it. See HKJ's reviews for actual measurements of actual chargers.
c_c
MBentz
Folsom, CA
c_c
Charging my 5000 mAh R/C batteries at a 1C (5 amps) rate takes a little over an hour, according to the digital display on the charger.
I have never timed how long it takes to charge one of my 3400 mAh 18650s in an i2 or i4 charger, but it certainly is not an all day affair. According to you it would take well over 9 hours to charge, and that had not been my experience. Perhaps my two chargers are sending more current to the batteries? According to my DMM, they come off the charger at ~4.21v.
Norm
Retired Administrator
Australia
What is the state of charge at when you start to charge your cells? They may well be a long way from fully discharged.
Norm
MBentz
Folsom, CA
Norm
Good question. Currently I'm only using one light with rechargeable batteries. The next time I charge the batteries I use in the SX25L3 I'll report back.
Curious_character
A good explanation of the Li-ion charge process is at http://batteryuniversity.com/learn/article/charging_lithium_ion_batteries. The lengthy process I described is for a full charge. If you simply charge at 1C for a little over one hour and terminate the charge when the voltage first reaches 4.2 volts/cell, the battery ends up about 85% charged -- it's the remaining 15% that takes the extra two hours. Some chargers probably cut off somewhere between the 85% point and full charge, resulting in charge times between 1 and 3 hours at 1C. The charger reviewed by HKJ in the link he provided does this.
c_c
