How many Amps?
Status
Not open for further replies.
Blue_Shift
Well-known member
Chattanooga, Tn.
I am going to have a 12 LED array. I want each LED to get .025A. (I sure hope that is 25 microAmps) So, do I need .3A? Then when it splits 12 ways, each LED will get .025A? /ubbthreads/images/graemlins/icon23.gif I guess I am asking if I should add the all of the amps up. Also, does voltage matter too LED's or is it just the amps that matter?
flash....
Well-known member
Winter Springs FL
I would connect them in parallel.
I think your trying to say 25mA or Milli-Amps.
1000 Milli Amps or mA = 1A or 1Amp.
In parallel loads Current is equal across loads so you would need to supply the 12 LED's 25ma x12 or 300mA. yes .3A is correct.
Empath
Administrator,
Staff member
Supporter
Oregon
This being crossposted to two forums will be closed. The one in the Electronics forum is gathering more responses, so that's the one we'll leave open.
Status
