So what lights are out there that work to preserve scotopic vision.
Surprisingly, (to me, at least) Dark Adapted Vision is still a controversial subject even in the 21st century. Searching around will show that this may be pursued by following any number of completely different strategies -- all of them having merit to one degree or another.
- Some will rely on any light as long as the people who sell it to him call it 'red'.
- Some will insist on a red light that won't directly interfere with their rods. (wavelength longer then 640 nm)
- Some will use white light at very, very low levels for this purpose.
- Some will use green light at very, very low levels for this purpose.
- Still others will use blue/green light at very, very low levels for this purpose.
I fall into the last catagory.
All of these strategies work to a greater or lessor extent -- most may be made to work very well. Part pf the variation lies in the fact that red light is so very difficult to use for shape recognition.
Another factor may be whether or not you may be being hunted by someone with Night Vision gear. Red lights have a huge IR signature which looks like a
beacon through any modern NV gear.
So really, there are many ways to do it that really work to a greater or lessor degree and there are also many who wil say that there is only one way to do it.
If you use red, you have to avoid
dazzlling your red cones -- I find red
very problematic.
If you use green or blue/green you must find a light that will dim down
much, much farther than most lights -- like the Rigel MIL-Starlight and the Photon Freedom NV green w/covert nose.
Most who use white, blue or blue/green strive to use them at levels that only bleach rhodopsin (visual purple) at very close to the rate it is produced -- so they never go very far in the hole.
With whatever color you use two operating rules are
iron clad -- (1) always use as little light as possible and (2) be very, very careful where you point it. With the reds any reflections may dazzle your cones and with the greens and blue/greens any splash will wipe out your rod's output in a heartbeat.
There has been lots written on the subject here and through the web and it's a great topic to read about (with all the different approaches). Then you can do your own experiments and find out what will work best for your circumstances.
It is by no means a one-size-fits-all situation.
