Hello Al,
So, your main concern has to do with the current supplied to each cell, and that current is dependent on the cells internal resistance.
First of all, lets get back to the original calculations.
Originally, we were charging 3 cells of 2200 mAh capacity, and came up with 4 amps as an acceptable charging rate.
Let's rework this for 2 cells of 2200 mAh capacity. When we parallel the two cells we end up with a battery of 4400 mAh capacity. Keeping our charge rate at 0.7C we would select a charging current (for 2 cells) of around 3 amps.
Your choice of cell internal resistance is about the limit of the range we can expect to see, so let's say that cell 1 has an internal resistance starting at 0.100 ohms and cell 2 has an internal resistance starting at 0.050 ohms. Please note that the internal resistance is dynamic throughout the charge and aged cells have a higher swing than newer cells.
As you have indicated cell 2 will start off charging at a higher rate, but it is still under the 1C recommendation. If I did the math correctly, cell 1 will be charging at around 1.0 amp and cell 2 will be charging at around 2.0 amps. Keep in mind that the constant current portion of the charge is only 20 - 30% of the total charge time. Once the cells get up to 4.2 volts, the current drops off.
Now, if we went for the 4 amp charging rate with cells starting at these internal resistances, we have a 2200 mAh cell charging at 2666, or at roughly 1.2C. Although this is a little high, it is still manageable. I don't think there would be any issues charging at this rate, but it is above the "recommended" rate.
0.100 ohms is about as high as you can get and still have a cell that is capable of delivering 80% of its initial capacity, so that is a good extreme to work with.
I took stock of the Li-Ion cells that I have been charging in parallel. The impedance of those cells runs between 0.056 ohms and 0.062 ohms. With these values, and with a 4 amp charge rate, I come up with charge rates ranging from 1.88 amps to 2.12 amps. Hardly any difference at all.
I guess I should advise people that if they have "crap" Li-Ion cells, they should recycle them.
If they insist on trying to use them, they should charge them individually.
The notebook battery problem is an interesting one. I believe that the balance protection used in these packs checked the voltage of the serial stacks to make sure they were equal. This does not check the cells that are in series.
My original computer battery pack is a 4S2P set up using 1900 mAh cells. This works out to a 14.8 volt 3800 mAh battery pack. The charging rate is 3.5 amps. I also have a replacement pack that has upped the capacity to 4460 mAh, so it must have 2230 mAh cells in it.
Keeping each serial string in balance helps, but unless there is individual cell balancing, there still can be the possibility of a cell getting out of balance.
I think the "issues" with the battery packs involved contamination in the electrolyte of the cells being aggravated by series cell imbalances. As a cell approaches or goes over 4.200 volts, it has the possibility of aggressively attacking the electrodes and plating metal lithium out. Add a good healthy dose of heat, and you are on your way to thermal runaway.
At any rate, I still maintain that parallel charging is safe, serial charging is where you run into problems, and individual charging is the best way to go.
Tom
