openbolt1
- Joined
- Feb 19, 2008
- Messages
- 343
How to eliminate that annoying gap between bezel & body using the DX sku:11074(pic's)
the geek asked a good question in another thread and I thought it might be useful here as well...
Pictures & text of the method I used to modify my Deal Extreme SKU: 11074 Drop-in so it would be gapless…
With regard to modifying the DX sku: 11074 (5) mode, Q5 D26 style "Drop-In" module to fit into SF C/P heads. CPF's: thegeek asked me to show and tell how I did this simple mod to the screw in pill/base so it would actually drop in.. WITHOUT THE ANNOYING gap between the body & bezel. I'm gonna miss that cool GITD O-ring I suppose…
[FONT="]I chucked up my Dremel tool into my vice so it would not move.
[/FONT] I then took the module and carefully turned/spun it while applying pressure to the very edge that was bearing against the rear/bottom of the bezel pocket of the flashlight body (nothing of course was done to the actual bezel itself).
I more or less just knocked the corner off the lower edge of the sku 11074 so it would now actually drop in and when the bezel is tightened down you can feel the module turning into the pocket and seating properly. I do not believe that I could live with a gap that I knew I could fix between the bezel and the body! I know it's a no-big-deal thing to a lot of guys judging by the comments I routinely read here, but I guess I'm a bit picky.
Time spent…about 3 minutes of grind & try, grind & try.
Here's the finished product…. This is a 18500 Leef body…
And this is my SF C2…
Hope this can be of use to some of us that are in this fix.
openbolt1
openbolt1
