roymail
I have a generic 6 volt lantern (spotlight) Ozark, I think? What would be the best led replacement bulb I can use that would be a good compromise between runtime and brightness? I would appreciate any suggestions. Thanks!
... although it's not quite as powerful, I assume it would run a looooong time... right? Thanks, angelofwarThe Craftsman LED ($14.99) is variable (1.5V to 14.5v?), so it will replace just about any krypton bulb, and will work inpalceo f the MAG LED's for your Maglites as well...just not as powerful...
A simple upgrade is the Craftsman LED upgrade...the power range on them makes the usable in most old krypton bulb flashlights...nothin' fancy, but they're easy to get and will give you around 50 lumens of white light as opposed to the typical yellow of krypton bulbs. I use these in my craftsman lantern and my old GI Crook-necks.
+1 for 4 cell magnum star...
I got a 6v lantern with a 4 cell magnum star.... it ownes my 6 cell maglite with a magnum star...
I am currently running the Sears LED upgrade in a DORCY 6Volt lantern, and it works just fine.
