How to lubricate O-rings.
nutz_about_lights
The Little Red Dot.
Hey all, one of the most common types of care that most CPFers have to do is lubricate the O-rings of the goods they unload their money on, aka flashlights. :nana:
Found this website (I've got no relation to it :caution:) that gives a good write-up on the process and how to go about lubricating your o-rings. Also states that why we should not use alcohol to clean off old grease. Basically everything that has got to do with o-rings and lubricants. Worth taking a look IMO.
http://www.southern-nikonos.com/WorkShop/Nikonos-V/Orings1-6/Part4/orings4.htm#anchor1
A few excepts:
''A lubricating-type grease is a viscous "gelled" material in which a liquid (oil) is usually suspended. Both the gel and its liquid are specially formulated to meet certain use requirements: temperature, separation...''
''And once the O-ring's surfaces are uniformly lubricated, any more grease you apply will neither improve the O-ring's sealability nor further reduce the coefficient of friction! ''
Hope you find the information useful. ;)
I read the document, which turned out more interesting than I would have thought.
However, I'd ask: I thought you needed to lube uncoated aluminum threads also, to prevent galling.
I'm assuming this didn't get mentioned in the article as it was about high-end camera equipment (and so without uncoated threads).
naaaa, i jus use those diver's silicon grease, which is being used on the diving mouth piece.
safe to even be consumated. works great.
:oops:
