How to open DX SKU 5435
rizky_p
13th Colony
Anyone knows how to open DX SKU 5435, because mine is DOA. I am sure i can fix it if i can open it first.
Thanks.
edit: oops just realized that i post in the wrong section in the forum no wonder i was looking for it.
Mod could you move it?
i tried it, could not find any notch as leverage. I tried removing/twisting the body from the head as i suspected there is a seems that supposed to be a seperate body but to no avail even after being subject to a small jet torch.
i am confused now:confused:
finally found way how to open this one, the brass ring actually unscrew the hard part is actually unscrewing it :mad: because there is no hole or anything to rotate it.
You can make use of a piece of soft stationery "Eraser" as an aid to grip and unscrew the brass ring in order to access the light engine. :grin2:
I have a couple of these:
wrap a little rubber around the body to avoid scratches and turn both wise and counter clock wise :)
Pablo
