I received my dealextreme 100mW green pointer and I have a piece of IR filter I would like to add. I can't get the head off the pointer. I put a screw in the hole and pulled as hard as I could it seems to be glued. Any suggestions?
Can I heat it up with a hair dryer and loosen the glue? or will the break something?
This is the IR filter I have: http://www.schneiderkreuznach.com/tipps/uv-ir_cut_filter.htm
When I shoot my TV remote control through the filter, it does not work.
