if a driver is really putting out 700ma?
um...disconnect one wire from the string and measure the current with your multimeter. It is not recommend to test without some type of load like the LED as some drivers fail when powered on without the output connected to anything. The way current is measured without an appropriate load what the driver sees is an short circuit and it may fry both your converter and your multimeter
Ok, so I have 3 CREE XRE's wired in series hooked up to a constant current driver of 700mA, powered by a 12 volt DC source...... I want to see how much power this setup is actually using. How can I do that?
Thanks in advance!!
CREE XREs consume 3.5V at 700ma
[voltage x current] x quantity = total wattage, or power dissipation
3.5 x 0.7 x 3 = 7.35W at a junction temperature [Tj] of 25C, or about 77F. as the junction temperature rises, power consumption will increase slightly. 7.35 here represents the minimum power output
if your wondering how much current is being drawn from the source you can measure it in two ways, one being more accurate than the other
method 1: determining your converter's efficiency, then using that efficiency value to solve for input current
Code:
Useful power output = Total power input x Efficiency
this translates to this. Solve the missing variable
Code:
Iout x Vout = Iin x Vin x E
0.70 x 3.5(3) = Iin x 12 x E
If your efficiency is 80%, then output power 7.35W divided by 80% of 12V equals ~0.7656, so at 80% efficiency the converter is drawing 766ma at 12V to output 3.5x3V at 700ma.
Method 2: grab your Fluke, set it to Amps, unplug the probe from the ma socket, stuff it in the A socket then run your multimeter in linear path to the converter from the battery. record the current input [if its set at amps, then it should be a positive decimal] take that decimal and multiply it with voltage yields the total wattage input.
