how to use nixie tube
star882
C:\\Program Files\\CPF
Do you know how to use this nixie tube?
By connecting the filament to 3v and the grid and anode to 12v with respect to the filament, i can get it to glow.
Chris M.
South Wales, UK
No access to the picture I`m afraid, but try this site:
http://electricstuff.co.uk
It has a lot of info on Nixie tubes of all kinds, and the site`s creator is very knowledgeable on the subject so you may like to ask him too.
Sounds like you actually have a low voltage filament display- as the true Nixies use neon gas and need some 70-90 volts to glow. It would be interesting to see it.
INRETECH
HILLSBORO, OR
That is not a NIXIE tube, it is a vacumn-florescent
A NIXIE tube is a set of digits, 0-9 connected to negative filled with Neon
The_LED_Museum
*Retired*
Federal Way WA. USA
Yup, that's definitely a vacume fluorescent tube or VFT for short. Really common in VCRs and similar consumer equipment. Filament runs on low voltage, grids run on anywhere from 10-35 volts, and I think the grid needs an AC waveform but I'm not sure. I haven't fiddled with one of these for ages.
Chris M.
South Wales, UK
Yes, having now seen the photo, that`s a Vacuum Flourescent Display, definately. Harvested from a dead VCR?
Nixie tubes are neon gasfilled and usually comprise a stack of ten metal wire figures of numbers 0-9, and a grid behind them. Application of DC voltage between that rear grid and one of the figures causes it to glow and indicate a number. Nixie tubes were also made which had a "starburst" or "figure-8" arrangement, that work like the VFD, LCD and LED numeric/alphanumeric displays, except they glow orange of course. To me though, you can`t beat the classic "ionized gas in a bottle" figural number Nixie. I`m not old enough to remember them the first time round, but since their discovery I have gained a great appreciation for this much maligned display technology.
Used reguarly as part of my testing procedures. Tht meter not only looks great and is easy to read, but it also accurate to within 0.01 volt of another meter (the Fluke below it) that I had proffessionally calibrated. Can`t beat that!
star882
I found this in a parts box along with old PC motherboards, hard drives, and all sorts of wierd parts.
I even found a block that gets cold on one side and hot on the other.
I want to install this display tube on the front of my old PC(Pentium Pro 200Mhz,128MB SRAM).
Chris M.
South Wales, UK
Can`t really help further with your desired application - the last (and only) time I had a VFD to play with, I dropped the silly thing while trying to hook up the grid heater supply
AKA Peltier Cooler Module. Neato things to experiment with. I have a design here for a homebrew personal air-con unit using solar panels, a few Peltier coollers, some flexible ducting and a pair of large CPU cooler fans.
Again tho, there`s that small matter of finding the time, plus the excessibely hot weather to inspire me to build the silly thing. It usually just rains here in Wales. Not that I`m complaining mind you, I hate hot weather....
star882
These display tubes used to be common, but now thy are going to LEDs. I found out that the old flat screen monitors have VFDs, but now that there are blue LEDs to complete the RGB LEDs, they are LED based from now on.
star882
I am not looking for a standalone clock, I am looking for a way to install this tube in my old computer, so I can control the display with software.
Chris M.
South Wales, UK
You will need a driver circuit, multichannel output card or serial port interface, and an advanced knowledge of programming to make this work. Above that, I know not. I have neither the degree of electronics nor programming knowledge to help further, sorry.
Seems like a lot of grief, for just a bit of fun. I don`t mean to pee on your Cheerios but if it were me I`d not bother.
FYI the time is prominently displayed at the bottom right of all Windows screens. Unless you`re running Linux, or something?
star882
I have windows 2000, and I do not want to have the taskbar show all the time(wastes screen space).
I think it is annoying to move the mouse to the bottom of the screen every time I want to see the time.
Of course, I want to view CPU usage and RAM usage as well.
I will have it powered by the internal power supply(my PC has 12v,5v,and 3.3v), and connected to the serial header.
Saaby
Utah
Edited because it was just a stupid post (Quiet you)
I'll never take 2 Excedren again...
