How's The Weather There ?
Pacific N.W.
Cold for this time of year, but oh so beautiful!
The picture was taken at 10:26 pm. The clouds were not visible. iPhone 12 is awesome.
NightStalker1976
Lamberton, Minnesota
Day 2 of the blizzard. 25MPH winds, blowing and drifting snow and reduced visibility. I'm glad that we filled the feeders earlier this week. It will help the cardinals, woodpeckers and juncos survive the storm.
bykfixer
John 3:16
Morning commute involved a summer-like storm collide with Jack Frost's special forces when all at once a really bright rainbow appeared. It would have been sureal if it weren't so sketchy driving in it.
I was like "well hell I'm gonna die so may as well snap a photo of the ordeal".....
rwolfenstein
We got an artic front that moved through the PNW, so the roads are covered in snow and ice.
Poppy
Northern New Jersey
We had rain until around 1:30 pm with temps in the mid fifties F. Then between 2:00 and Now 5:30PM it dropped to 17F actual temp with 20 MPH winds that make it feel like -1 F.
I needed to run a quick errand, and had to scrape the windshield, and pry the car door open from the frozen rain. The silicone grease I applied to the weather stripping helped, but it was still a little sketchy. In the short period of time it took to scrape the windshield, my pant legs felt like they were stiff and frozen.
All I can do is pray for those who are in the mid west and suffering with -30 windchills.
I told my daughter, that if we decide to go to my son's house tomorrow, that we should all bring long johns, or flannel/fleece pajamas, incase we need extra layers, because we are stuck/stranded in our vehicle.
In this kind of weather one should dress like he will be walking in it, and take the layers off once in the car.
Stress_Test
This was the coldest day we've had here that I can ever remember. I think it was about 5 degF for most of the morning, strong winds 15 mph but gusting higher. It stayed about 8 deg most of the day it seems, and now the local weather station is reporting 10 deg.
Last night when I went to bed, the electronic thermometer I have in the room said 58, and when I woke up, it was 52, so that room lost about one degree per hour from about 12am to 6am. (I normally don't use the central heating unless it drops down to 50 inside; small portable heater handles the bathroom). When I got home (early) at about 3:30pm, it was 49 deg inside so I put the heat on 51.
Wasn't bad at all in the car going to work, since we had a delayed start time so my car got a little bit of sun before I left. At work though I was getting the full wind blast in the parking lot. It was like walking into an industrial freezer with the blower fan on high. Actually, I have been inside of one of those before, and I think it was only 14 deg, so this morning was worse than that.
Any exposed skin hit by that wind felt like someone was pressing a block of ice against it. I would've needed a full ski-mask deal for my head rather than just the coat's hood if I was going to be out in that for any length of time. The wind forced its way in and around inside the hood unless I had my back to it. My upper body felt insulated enough, except that I hadn't tucked in my shirt, so as I bent down to pick stuff up, the wind got in even under my hip-length outer coat and felt like someone pored ice-water down my sides. I had long underwear and jeans on, but still could've used an outer shell layer for my legs since they still felt pretty cold.
All in all I would NOT have wanted to spend very much time out in those conditions today. Y'all that live with conditions like this every winter are a tough breed!
Stress_Test
Chaunce, biter cold is good for your dogwood and fruit trees.
Today we hit 67° Times like this across US, I'm happy to be in warmer climate 😎
Our forecast for New Year's is about 67 also. This region tends to bounce around a bit as far as temperature swings.... but this is kinda ridiculous!
aginthelaw
NJ, USA
Need i say more…?
