VidPro
sometimes we wonder what the heck topping and slowing down at the end of charge is for, what purpose does it serve to slow down neer the end of charge on say a li-ion, why not just keep pumping in the same power?
and THIS is how i always pictured it.
😀 This is your mostly discharged battery
And the chemicals that have converted to the other state
as you can see some of the chemicals were/will never fully
convert , it still has a few ma left
😀 at the first of your charge
there are many and many willing chemicals
ready to convert over to the other state
so potentially you can slam it pretty hard
😀 and the charge will be "accepted"
lots of chemicals ready there to be changed up
😀😀 neerer to the end of charge
more of the chemicals have already changed over
😀😀😀😀 so the power going in is going to less stuff
😀:green:😀:green:
so if you hit it hard then
:green::green:😀
😀😀 most of the stuff is already switched over
😀:green::green: most of the stuff Cant "accept" a charge
😀:green:😀:green:
:green: if you keep pounding it in more of the power
:green:
goes out as heat
:green:😀😀😀
:green: these things take time , like any chemical reaction
:green:
😀😀😀:green:😀😀 eventually everything that will change state
😀😀😀:green:
already has changed state
😀😀:green:😀😀😀 so the power going in is going to nothing
😀😀:green:😀:green:😀 and just wasted as heat more and more
:green::green:😀
😀😀😀😀:green::green:
😀:green:😀:green:😀:green:
😀😀:green:😀😀:green:
:green:😀😀:green:😀:green:
:green:
😀😀:green:😀
😀😀😀:green:😀😀 and keep this up after the thing is mostly
charged up and you just
😀😀:green:😀:green:😀 start destroying stuff
😀:green:😀 that was already happily charged up
:green::green:😀😀😀😀
:green:😀:green:😀
:green:
:green:😀:green:
😀😀:green::green:
:green:
😀😀:green:😀
😀:green::green::green:😀:green: by slowing down, and topping and stuff
😀:green:😀:green:
at the end of the charge
😀:green::green:😀:green:😀 you have a better chance of
:green:😀:green:😀:green::green: achieving fuller conversion
:green::green:😀😀:green:😀 without destruction
😀:green::green::green::green::green:
:green:😀:green::green::green:
:green::green:😀:green::green:😀
next week i will explain the cookie monster 🙂
more of the chemicals have already changed over😀
😀:green:😀:green:
so if you hit it hard then:green::green:😀
😀:green::green: most of the stuff Cant "accept" a charge😀:green:😀:green:
:green: if you keep pounding it in more of the power 😀
:green:
goes out as heat:green:😀😀😀
:green: these things take time , like any chemical reaction:green:
😀😀😀:green:
already has changed state😀😀:green:😀😀😀 so the power going in is going to nothing
:green::green:😀
😀😀 😀😀😀😀:green::green:
😀😀:green:😀😀:green:
:green:
😀😀:green:😀😀😀😀:green:😀😀 and keep this up after the thing is mostly
charged up and you just 😀😀:green:😀:green:😀 start destroying stuff
😀:green:😀 that was already happily charged up:green::green:😀😀😀😀
:green:😀:green:😀
:green: 😀:green:😀:green:😀:green:
:green:😀:green:
😀😀:green::green:
:green:
😀😀:green:😀😀:green::green::green:😀:green: by slowing down, and topping and stuff
😀:green:😀:green:
at the end of the charge😀:green::green:😀:green:😀 you have a better chance of
