Originally posted by AlexGT:
I think I´ll try the longer screw trick and see
Alex
<font size="2" face="Verdana, Arial">Wooah!
I hope you did not get this idea from me.
Don't do it!
It will mess up worse.
Here is the deal.
PROBABLY...the post that broke on you was one of the front ones. Measure them and you will find them a tad smaller. Of all the ones I broke...total about 6-7 times..it was always the 2 thinner front ones rather than the 2 thick back ones.
Things I did to help.
Found some aquarium tubing and slipped over the front posts to make them stronger.
I noticed that the posts "SPLAYED" rather than stripped.... This caused the stripping feeling.
I coated the screws with light lube and filled the holes with a mixture of plastic shavings and epoxy...pushed the screws in...waited for it to harden...then screwed it out. This worked for about a month.
Epoxy a brass insert for a water faucet over the front post to keep the splaying down.....fill with epoxy and do the screw thing. THIS WOULD HAVE BEEN PERFECT EXCEPT THE CASE TOP DID NOT FIT DOWN....scratch yet another Eternalight. I took the guts and made a home brew case.
Took the back posts that were perfect from the above eternalight case...and tried to mount it in the front...and epoxy it in. This did not work...
Scratch another Eternalight.... Made a home made case for this one.....gave to grateful friend.
SO...why not give up with them altogether. I love the functionality of the Eternalight more than any light I have. It is a night light...and a bright light.....USES LITHIUM batteries for the cold weather where I live... it is a toy!
The new case design fixed all of MY particular problems. I admit, I am very rough on things. The new design is perfect. I am not too crazy about the magnet. I want to remove it and put a piece of alien skin in the "hole".
I have not removed the magnet as I hate to do anything to this model that is working perfectly! I am afraid I will screw something up!
FYI...here is the last trick I did yet on another eternalight.
Take out all the screws, remove the rubber insert, and put the case together with a high quality PLASTIC electrical tape. It suprisingly looks ok.... I wrap one continuous piece from the top of one side...around the bottom...and back to the top of the other side. No water tight etc...but I don't dunk mine...
I gave that one away to a friends daughter. She loves it. She keeps it beside her bed and sleeps alone now! She keeps just one white light on at night. Her dad made me an all brass INFINITY base for thanks!
