I got my X10 and have some?
jtivat
Grand Rapids
First let me start with this light is awesome the best light I own (excluding durability time will tell) and the brightest. I opened it and charged it, then fired it up twice worked great, then on the third try the 60L LOLA went out
however I bought a 110L LOLA and it is working just fine. I also bought a spare battery for it, once the spare was charged I tried it and realized it only had one O-ring and the one that came with the light has two. It is also much tighter and feels much better. How many O-ring do other X10 batteries have? Next question how long should my battery last with the 110L and 500L on? My first charge with the spare battery I got 12 min. on high is this normal? Last question for now, after doing run test my bezel was to hot to touch is this normal?
Thanks
It's not surprising that a powerful light like this has a hot benzel after running a 10 min test. Even if for running a 5 mins test, it should get pretty hot. You are dealing with lots of light power here....
Ok thought of more? Can the batteries be put on the charger without the light? Also after testing the first battery I put it on the charger and it went green in five minutes?
"The 10X911 flashlight system includes the 10X000 flashlight with the 500 lumen MN31 Lamp Assembly, 60 lumen MN30 Lamp Assembly and a rapid and smart AC/DC charging system. The C900 charger head will accept and charge the flashlight with the battery in place, and it comes with both the T210 AC power source and the T001 DC auto plug adapter. The battery for the 10X is built into the "body" of the flashlight, which we refer to as the B20 battery module, and could be charged on the charger while the flashlight remains in service using a spare battery module or as an alternative, the flashlight (body with head attached) could simply be put on the charger to charge the battery."
Quoted from http://www.tacticalflashlights.com/surefire/10x.htm
Your charger detected a false peak in the battery....Re insert and recharge...
--dan
With the LOLA MN30 (60 lumens) & MN31 HOLA on at the same time I get ~14 minutes max. So I would say you are not too far off.
Let me know if both batteries give you the same run time.
The O ring situation is odd. I would imagine they should both have 2 o-rings. But if the battery pack with only 1 o-ring fits tighter I wouldn't mind, since I think the 2 o-rings on mine are to small.
I would call Surefire about the LOLA going out, they will ship you a replacement, also ask about the o-ring, they will probably send one of those too.
Opps that came across wrong the one with two O-rings is much tighter it feels really nice compared to the one with only one.
