BIGLOU
- Joined
- Jan 14, 2009
- Messages
- 717
Stayed up late again playing with my flashlights. I decided to run my M61 on an 18650'd SF 6P with a zero resistance Z41 upgrade on 2 AW RCR123s. I pulled my AWs from other single cell lights and I charged them on a WF139 charger so they have an even or almost even voltage before the install. While babysitting the charger I saw one battery was done (green light comes on) I waited maybe 15-20 min. until the other one was done. The first battery off the charger was 4.17V and the second was 4.16V. I was too inpatient and could not resist to fired it up and I did. The light went bright for two seconds and then dimmed to a blueish light.:fail: Here is my problem my flashaholicism did not allow me to wait the 1 minute or so or just leave it until the morning before installing the batteries and firing it up rule. Is this want happened and caused my light to go I'm pretty bummed out right now and my only fix will be to buy another. I wanted to know if some one could break down for me on what could have happened. Just for the FYI this is also the first time I used the zero resistance TC on two RCR123s on my M61. Also I dont know if it I'm getting the "This light is just not bright for me anymore" syndrome but it did appear not as bright. This is the reason I wanted to run the AW RCR123s for a higher voltage. I checked the 18650s I was running it with prior and one was 3.97V and the other was 4.07V just to see if it was running regulated. Why is there light emmiting inside the LA if it went ? I dont see any burn marks maybe only happens with Incan but the LED looks dead but there are two little thingys that turn on super dupper low low low on two corners of the LED. Can this be repaired? Thanks yes I deserve a
