I need a bright LED for a pinhole light source.
iansmith
I have been experimenting with making pinhole light sources out of 5mm LEDs.
What I do is sand down the lens as close to the actual emitter as I can get, polish it, then cover it with a thin bit of metal with the smallest pinhole I can make in it.
(Click for bigger image)
I am currently using a RL5-W18015 which is rated at 18,000 mcd (no idea how they measured that) and it works, but I need as much light as I can get so I am looking for a replacement.
Since I remove the lens, the beam width doesn't matter to me.
And unlike most applications, the size of the emitter does matter. A large emitter like in a Luxeon is not as usefull since I will be covering most of it up and so most of the light will be blocked.
Any suggestions? Out of the box ideas are welcome too. :)
At Newark Electronics I found a 18000 mlm (I think that's another way of saying mcd) 5mm white LED. Newark p/n 52K5249. TT Electronics OPTEK Technology p/n OVLEW1CB9. Cost was $0.934. I love how they use thousandths of a cent in their pricing.
Haven't found any 5mm LED's that are over 18000.
snarfer's idea is pretty good. use a condensing optic on a high-power first, then cover the end of that with the pinhole shield
I'll keep a lookout for some spare fiver and a good condenser lens. The web page with the Polymer Optics lenses were good, but the smallest I could find was one that focused on a spot 6mm wide. I imagine I should be able to find a lens that will get it down to a point since the fiber is going to be very thin.
I ordered some 55,000mcd lenses from ebay, I'll try those out too.
