Bright Scouter
OK,
I don't use a flashlight in my work. Just everyday stuff. Plus I am a scout leader so camping and some backpacking. I always carry the Arc AAA-LE and usually a UK4AA. I have the Arc LS on order. But I want a small relatively powerfull light for when the leds aren't enough.
I see the admiration for Surefire. So thinking towards them,,,
E2/C2/3 ?s How much bigger is the C2 than the E2? The surefire site lists length the same, but can I assume the C2 is larger in diameter? I was leaning toward a C3 since it seemed to only be the length of a 123 longer.
E2/C2 vs UK4AA How much brighter will the Surefires be than my UK? I like the size/form factor of the UK and it seems the E2/C2 would be similar. I would hope the C3 will have considerably more output than the UK.
I also liked the C2/3 since I could change to a higher output lamp. My leds will be my main use light, so run time isn't terribly important.
Any other suggestions/ideas?
Thanks
Del
Thanks
Del
