This trick takes a bit of work, but it works. Get a stiff emery board. Dollar stores useually have them, mine is about 1" x 6". File the LED flat until just above where the bond wire is, then round it off to get a slight dome. Then use the finest sanding paper you can find. I use 1200grit, and smooth it as best you can. then do a final polish sanding with a bill of US currency, The NEW 20's work best, but any bill not super worn works well. This will give you a light source with close to a 180 degree output. I have used this method, and it works with reflectors as well as LUX optics.
Hope this helps
Jeff
