markdi
I never mentioned mounting the bulb
I measured the distance from the seat of the bulb flange to the center of the filament of the h4 bulb using a caliper
and compared it to the center of the arc cavity of the d2s bulb to get a rough idea of the bulb position.
then I had a aluminum tube that I cut that fit pretty tightly into the bulb hole on the reflector.
I cut it to an appropriate length(I epoxied it to the base of the bulb with the glass bulb centered in the short tubular spacer) so that I could adjust the bulb by sliding it in or out of the reflector-to adjust the spot.
the arc carataristics change while the bulb is warming up.
so you need to mount and support the reflector and bulb (outside of the thor)aimed at a target.
let the bulb and reflector warm up for 5 minutes.
adjust your bulb position for best spot.
epoxy it into place.
the bulbs have such a long life that it will last a very long time unless you drop the light and break the bulb.
this post would have made more sense but I ate so much chocolate that I am getting kinda sick.
and I am a johny come lately to hid thor mods.
many did it before me.
