Lighthouse one
I won this light at the recent FCW 6 camp out. www.Lighthound.com was the donor. I showed this light to several of my friends, and they thought it was neat...and powerful for a 2 AA light.
Here are a few shots to show off it's unique design.
I decided to test it underwater- since it lists 1 meter ok.
I left it in water for a while- then took it apart to look for leaks. None.
The larger o ring on the body certainly helps.
The construction is very solid. Notice how thick the tube walls are. You can also see the OP reflector- which gives a nice smooth light pattern.
Here is a ceiling shot to show the smoothness of the light.
The two levels are 10 and 100 lumens. The ratings are a bit conservative. This light is quite strong. What is also excellent is the 70 hour run time on low.
THe light has a great switch. Nice to operate...light, but not touchy. It's a forward clicky- so you can turn on the light with a half press.
The switch operation has a mode memory....if it's off for more than 2 seconds it will come back- on that mode.
For around $45 this is a great light and also a really cool light to give as a gift to a friend or family member.
