Barbarin
One of my projects is making a scuba flashlight using a Eternalight Ergo with 8 LEDs or a Photon Fusion. As you now the critical point is the switching, and the only reliable switch for a multimode is the magnetic option, wich I don't like very much. The rubber option was one of my favorites, but there is a problem with the pressure, unless we increase the internal pressure of the flashlight. I've been thinking about the idea of waterproofing a flashlight circuit by filling it with a dielectric liquid (oil, cooling liquid...)At first the idea seems interesting, and the liquid will help in the cooling and the maintenance of the circuit, avoiding corrosion. The temperature curve should be softer,and if the flashlight is made of aluminium the interchange of heat
must improve.
Now is time for the "techies" to tell me why the idea is not so good, or just to recomend whatever they think about my homemade ideas.
Thanks in advance.
must improve.
Thanks in advance.
